chris.knudson
You're making me rethink the name of this pedal...But that guy looks like he's ready to shift something, and it ain't phase.
Awesome!YES!!! New fuse and it works fine! Even remarkably quiet!
congratulations!YES!!! New fuse and it works fine! Even remarkably quiet!
I still need to replace the power cord, needs some major deoxit love for the pots and either just needs some deoxit or new pre amp tube on the bass side.congratulations!
Is it called "the Golden Penis"?Getting ready to try again on the graphics for my phase shifter pedal. This was my first attempt at a film-free waterslide, and I baked it too hot for too long. Had to literally scrub the film off with some Isopropyl, and I seriously faded the graphic in the process. Think I'm going to sand it down, paint it, and try again.
Harvested the semis from an old Japanese hifi system, just for fun, before throwing it away.
Any of these parts stand out as something worth trying out?
Transistors
ICs
- A872
- A965
- C2546
- C1775
- C458
- A1029
Some more stuff I couldn’t real the labels on yet, but most of the transistors there’s at least a dozen of.
- VC5022
- HA1457
- BA684A
- SHARP IR2434
- HA11225
- NEC μPC1161C
- HA1197
The HA1457 seems like it’s got potential.
There are a handful of the LED level meter chips— might have some use for those I guess.
There’s also easily 70+ of these diodes. Don’t recognize them, but I’m guessing the H is probably for hitachi since there are a lot of other hitachi components in it. Anyone know about these? Just silicon, but if they’re some magical mojo clipping diode ala KoT I’ll go thru the effort of desoldering them for future use
That’s awesome! Demo?YES!!! New fuse and it works fine! Even remarkably quiet!
Thats my favorite kind of lettuce.
If you can drill perpendicular through a board then you can lay the knob against it and use the whole as a pilot guide possiblyJust need to think of a way to drill them perfectly perpendicular to the bottom
Perpendicular for the shaft or a set screw? I think a set screw would be easy as you can clamp them in a vice and then turn it on its side or turn your table 90 degrees. For the shaft might be difficult. My thought would be to make some sort of a jig perhaps a molded one the knob presses into maybe even the mold itself. I have always had a hard time clamping irregular shapes without damaging them and holding small pieces on the drill press is always hard.Lil babies. Just need to think of a way to drill them perfectly perpendicular to the bottomView attachment 65602
Got another commission for a Dandy Horse
Customer is gonna have a vinyl decal applied to ape the looks of the OG, so we went with a bare box.
Would there be any room to scoot it down?The spacing on this kewpie fuzz is crazy tight!
