What's in the mailbox? 📬 📦
Got a dose of Sheepylove today straight from @szukalski, plus a couple of storage boxes, I'm planning to put transistors, IC's and diodes in those. I've got the resistors and capacitors decently figured out, but with all those parts in their own Tayda baggies in one big bag means it's annoying to fish for the correct ones.
Baseball card holders.
Last of my PCB's on the way got here! General Tso, Fuschia Fuzz, Germanium II Distortion and the Magnetron Delay. I think I'll have General Tso "jump the queue" since I've heard so much praise for it, even though I (like a lot of other people, it seems like) don't really like compressors with guitar tones.
Me too me too!
Thanks for the tip @MichaelW !
I've mostly left my boards fluxy, but I'd like to clean up my act. I bought a bottle of that stuff a while ago, but honestly haven't used it that much... I haven't tried dunking a board - I was trying to squirt some on the board then toothbrush it and it was kind of a mess. Are pedal components generally happy with getting submerged? Doing that before the pots are mounted I'm guessing?
I filled a 1590BB enclosure with about 1/8” of the fluid and laid the boards down in it for about 30 seconds. Most of it came off in the solution, then I took a toothbrush and cleaned the rest, dragging it down into a paper towel.
That's why I use a spray bottle and a toothbrush. It uses the least amount of solution and a bottle can last a good long while.
@Erik S I also "rinse" the flux remover (with the mess) off with 99% IPA. (It actually doesn't really matter what concentration IPA you use. Once you open it, it's no longer 99% because the alcohol absorbs moisture)
