Probably printed on the board under the cap............
Arduino project yay!!!I gotta give Jackson Audio credit for the design on the Prism, this is a really cool pedal, and I'm not even talking about how it sounds.
The whole thing is controlled by an Arduino nano... the relay switching, mode switching, gain level switch, etc.
The Gain toggle switch controls digital potentiometers which shift the gain levels for all three of the selectable gain stages.
The Mode toggle switch controls a series of relays to activate the appropriate gain stage. (BJT, MOSFET, or JFET)
The Boost pot is dual-gang, one gang is the actual analog gain control, the other gang sends a reference voltage back to the Arduino to change the color of the indicator LED as you turn the Boost up.
The star of the show though, to me, is the little LED diagnostic indicators like you'd see in high-end commercial / industrial electronics.
With a quick glance and no test equipment whatsoever, I can see that all three power supplies are up and running, the pedal is in bypass, the signal is not being muted by the opto, and I can see which mode is selected by the toggle switch.
This reminds me of my old days working at the repair shop.
Whoever designed this (Brad Jackson?) did a fantastic job, it's not every day something in a pedal impresses me this much. Good job Jackson, this is awesome. I honestly don't even care what the pedal sounds like at this point.
(Forgive the dust, this pedal has been sitting for three years)
I have the Golden boy, would you like to trace it? I mean you can borrow it if you want :8I gotta give Jackson Audio credit for the design on the Prism, this is a really cool pedal, and I'm not even talking about how it sounds.
It’s practically an honor just to trace it.I gotta give Jackson Audio credit for the design on the Prism, this is a really cool pedal, and I'm not even talking about how it sounds.
Hidden trannies under the ribbon cable? That's like to stop guys you cold yo....
So, melting the tops of your capacitors is cool? If it is, just call me Miles Davis.
They also hand paint fake stripes on all the resistors. Some real artisanal shit!
This is where things should at in terms of innovation. I guess when you're powering an Arduino, then using non-latching relays doesn't make much difference to the power consumption!I gotta give Jackson Audio credit for the design on the Prism, this is a really cool pedal.
If only they'd have spent the same amount of effort on using the correct footprints for the electrolytic caps in the upper corners (edit: and middle) of the board...Well we're just full of surprises, aren't we?
Crunch Box with a charge pump/bipolar supply? That was my theory.
