drgonzo1969
mmmmm sanndwich
mmmmm sanndwich
Is it a sandwich or sammich?mmmmm sanndwich
Depends on the funk.Is it a sandwich or sammich?
Any update on this?
Any update on this?
I never could have told if you hadn’t pointed it out! Is that for a pedal or to mount in a guitar? Also how do you solder in, out and power?Just a little boost...
Really disappointed that I installed the 390R backwards....
At first I thought that 1n5817 was a MELF resistor.
Flat Boost? How about a wide Q mid boost? Like the Demeter Fat boost?I had pedals in mind but I suppose you could use it in either?
They're through-hole pads, they're just filled with solder from testing.
That's generally how I connect offboard wires, especially if I'm planning to remove them... fill the pads with solder and "surface mount" the wire onto the pad. Faster and more secure than any quick-connect, socket, or clip lead.
hmmmm lemme guess....a Revv pedal?
ehx bender royalehmmmm lemme guess....a Revv pedal?
I actually had a chance to somewhat trace the Fortin Blade from an old bandmate, couldn't pull any components though. It is yet another TC Electronics Integrated Preamp that's been modded, I had actually used your clone board to make some approximations. I'll have dig one of them out to see what I did exactly since it was about three years ago.
ehx bender royale
Well according to Schrodingers thesis it can be either or.....or not.......maybe........So Robert thumbed up both the Revv and the Royale comments, but it can't be both...
