Robert
Reverse Engineer
So, what's in the custom shop "modules"?
That's what this was. I'll have to see whats in the standard version next.
Is it possible they are trying to avoid technical jargon that could be off-putting to a layman? I'm trying to imagine the most generous interpretation.
"Casing Design*: All of the parameters of a case -dimensions and plate thickness of the case – affect overdrive sound. We employed the best size case for our Integrated Series to provide the ideal sound. Its weight has also been optimized to deliver the best sound."
"We developed a custom turned brass knob to reduce vibrations in the shaft and wiper of the semi-fixed resistor used for each control and suppress harmonic components that might adversely affect sound."
Despite those discoveries, this one just got a plain old 1590XX and Boss-style reflector knobs.
I ended up on a hifi forum once. I figured that’s It’s a strange hobby for people who:Are these folks also in the audiophile business? Maybe selling $2k power cables or little stands for wiring or that kind of stuff? Sure looks like a natural fit!
@Robert - on the Stock Fuzz (Strymon Canoga) I am having some challenges locating any toroidal 680uH inductors of that size (looks like ~10mm OD in pic above), the ones I'm finding so far on Mouser are much larger, ~25-30mm OD. That thick copper wire suggests that I want low DCR, too. I do see some axial low-DCR inductors, e.g., from Wurth. Any suggestions for toroidal sources? Thanks in advance.
How quickly did those coupon codes go? Hopefully you're very busy right now!
How quickly did those coupon codes go? Hopefully you're very busy right now!![]()
