What's on the workbench?
I might be wrong, but I don't think the board offered by any of the other guys is exactly the same as the MXR. I believe those are JFET adaptations of the amp schematic.... This is (quite) a bit different. This has opamps, and more opamps, and what's that? Oh.... more opamps.
Not saying that's better or worse, just not the same.
(If there IS a schematic of this thing already floating around I'd love to see it, it could sure save me some time)
It's going to be a little while, that circuit is rather complicated, but I did crack it open a few days ago to put it in queue.
I made the PCB Guitar Mania version of this and was highly disappointed in it, though now there is a modded version of the build doc claiming that it actually gives it some high gain sounds (lots of complaints on the original board that it was essentially just an overdrive, certainly not high gain). I haven't gone back and switched out parts to see if they actually fixed it, but theirs certainly uses a bunch of op amps and no JFETs, not sure how it matches up to what you've found: https://pcbguitarmania.com/product/wolfgang-5051/
Edit: It has two JFETS, an input buffer and maybe the second is an output buffer of some kind? A little strange, it's right before the EQ section and the last op amp, which I would assume is acting as a buffer as well.
That being said, I'd like to build this again and see how it sounds from a better source lol
Wolfgang = Bajaman's EVH overdrive. It's definitely not a high gain pedal. Both jfets act as a buffers.
