SameI've had no issues with JLCPCB
Amplifyfun makes killer faceplates, FWIW. Lots of materials available, and if you opt for UV printing he can do multiple colors. He also does laser etching.I'll take a look again at JLCPCB. I have been meaning to use them to make a faceplate for my Bassman amp.
Thanks all.
I spent a few hours on it the other day to see if it could replace DipTrace but couldn’t gel for a couple of things (custom font control and manual routing ) so I went back to ole trusty, broken on Mac, DipTrace.Yeah, JLCPCB... and I've been using EasyEDA. I've laid out several boards, and they're all working so far...
I finally stopped ordering 15 or 20 boards every time time I use JLC. Just so tempting, but I almost never actually need even 5 and my last order came in at under 6 bucks, shipping included. Three would've run me around 24 bucks at OSH.I'm another happy JLCPCB client. I've used OSH Park too. I think aesthetically the OSH Park boards are nicer looking, but the JLCPCB boards are fine and it's hard to beat being able to get 10-20 pcbs manufactured then sent to my door for under $20.
I'm weirdly impressed that, since it's an x86 Windows App, running in Wine, then translated through Rosetta to run on Apple ARM, it runs at all.ole trusty, broken on Mac, DipTrace.
The defaults are fine. The only things I ever bother to do is specify a location for the order number and change the PCB colour.I have a related question for those who order PCBs from PCBWay or JLCPCB.
They have many options you can tweak when you start an order... are the defaults all good for pedals, or are there specific settings that need to be changed?
Also, are 1.6 mm think and 2-layer the standard for most PCBs?
Was not aware that was an option and will be doing so going forward, thanks for the tip!The only things I ever bother to do is specify a location for the order number
