Paragon Trimpots
dorrisant
I have built the Paragon and love it. That said, I'm building another. Does anyone have a part number and/or source for trimpots that fit precisely on the pcb?
Tony
Okey, Thanks!
My ones have a little "POP" sound when I switch on with the 3pdt. Can I solve this? It's sound pretty good
From Analogman's website, the trim pot all the way down is stock. For darker guitar or amps, turning the treble up a bit helps brighten them :). I used a daughter board for switch and trimmers to make them external, but having built this I wish I put just did 4 switches. 2 on-off-on for the clipping arrangements and 2 that would short the trim pot for stock setting, and then a treble boost that is user defined by the position of the trim pot.
Okey, Thanks!
The Paragon has ant-pop resistors on the inputs and outputs. It's possible that something outside the pedal is causing the pop. What do you have before and after the Paragon in your pedal chain?
Shouldn't be a huge pop. The pull down resistors should prevent excessive pop. I've had dodgy switches that would pop even with the pull down resistors.
Edit: Looks like Chuck beat me to it.
Carl Martin Compressor Limiter, but when i plug allone it plug
Yes, we soft switch the LED. First confirm it's the LED either by disconnecting it so it's always off or temporarily jumpering the LED terminals on the stomp switch so it's always on. If the problem goes away, it's the LED.
Another question, It could be possible changue the Paragon switch PCB with two pcb's for 3pdt?? THX you all.
Hey Chuck, just wondering, all my KOT clones have a slight pop too, with nothing before or after them, plugged straight into the amp and the guitar. I wonder if using a smaller value pulldown resistor at the output would help. I usually put 100k there, not 1M. Just wondering. :)
Haha and here I am two years later asking myself the same question 😂
I’ve seen reports of the Analogman KOT popping a bit so that’s that.
At the output I usually omit the electrolytic 1uf in parallel with the film 1uf and directly use a film or mlcc 2.2uf, but I guess that cant possibly make any difference right?
Maybe I should try 10k pulldown resistor…
Film & MLCC caps should not be leaky, so lowering the pulldown resistor won't help. I'd stick with the 1M pulldown. 10K will load the tone network too much. Those electrolytic output caps should be tantalum.
Actually, the more I look at this circuit, the less I like it. Time for a Boneyard edition.
This one is overdue for breadboarding.
I'd be all over a Boneyard Paragon!
