I have built the Paragon and love it. That said, I'm building another. Does anyone have a part number and/or source for trimpots that fit precisely on the pcb?
Tony
Okey, Thanks!
My ones have a little "POP" sound when I switch on with the 3pdt. Can I solve this? It's sound pretty good
The Paragon has ant-pop resistors on the inputs and outputs. It's possible that something outside the pedal is causing the pop. What do you have before and after the Paragon in your pedal chain?
Some solution if the led is the problem?Could be the LED too
Haha and here I am two years later asking myself the same questionHey Chuck, just wondering, all my KOT clones have a slight pop too, with nothing before or after them, plugged straight into the amp and the guitar. I wonder if using a smaller value pulldown resistor at the output would help. I usually put 100k there, not 1M. Just wondering.
I'd be all over a Boneyard Paragon!Film & MLCC caps should not be leaky, so lowering the pulldown resistor won't help. I'd stick with the 1M pulldown. 10K will load the tone network too much. Those electrolytic output caps should be tantalum.
Actually, the more I look at this circuit, the less I like it. Time for a Boneyard edition.
This one is overdue for breadboarding.
