Stuff
So i might be the only person on this forum that’s never played a tube screamer I’ve been meaning to build one but haven’t gotten around to it def going to check that out!
Fack!
Amateur hour!
Moving the CD4049 buffered / unbuffered saga here @Feral Feline .
I hear no true audible difference, but the proof is in the impedance if my thinking is correct. I’ll set up a 1Hz sine wave and a variable load between the circuit and the scope. I suppose I could also measure at the six input / output gate pins if needed. The pedal sounds great btw!
@Feral Feline, I have some CD4049Bs arriving today. 🤷‍♂️
Far out, I'm on it...as soon as I find my bench...it's under a ton of parts atm.
Also, I think I've got more versions of the 4049 than TI. No 14-pin versions like you though...:ROFLMAO:
The worst part about that, and stripboard building in general (as far as I have experienced so far) is that if you mess up, it’s almost always easier to start over than to try and fix a mistake…
Exactly. It helps to have a claw hammer nearby for emotional closure.
