steviejr92
Authorized Vendor
This setting has the perfect amount of overdrive btw
It’s a decent starting point…for clean dial back the volume, and crank the master volume, and lose the Fat Switch….just another starting point for you,This setting has the perfect amount of overdrive btw
I love this one…So i might be the only person on this forum that’s never played a tube screamer I’ve been meaning to build one but haven’t gotten around to it def going to check that out!
dude holy @*%# thats a super clean build btw! so what mods make this guy special if you dont mind me asking? unless this is a normal TS?I love this one…
Thread 'PedalPCB YATsa stato solida?'
https://forum.pedalpcb.com/threads/pedalpcb-yatsa-stato-solida.11160/
Thanks! It’s a stock build, but I love how it worked out.dude holy @*%# thats a super clean build btw! so what mods make this guy special if you dont mind me asking? unless this is a normal TS?
Indeed.Amateur hour!
Dude I would just have the inside on display for everyone to see in my home hahaThanks! It’s a stock build, but I love how it worked out.![]()
@Feral Feline, I have some CD4049Bs arriving today.Moving the CD4049 buffered / unbuffered saga here @Feral Feline .
I hear no true audible difference, but the proof is in the impedance if my thinking is correct. I’ll set up a 1Hz sine wave and a variable load between the circuit and the scope. I suppose I could also measure at the six input / output gate pins if needed. The pedal sounds great btw!
@Feral Feline, I have some CD4049Bs arriving today.![]()
Far out, I'm on it...as soon as I find my bench...it's under a ton of parts atm.Anderton's EPM: Project #24...
Phase 1, in which Doris gets her oats.... I have decided to build Craig Anderton's Tube Sound Fuzz, from his Electronic Projects for Musicians. Here are the pages that cover the project: I am posting the pages without permission...but this is for "pedalogical" purposes, so its ok. Besides...forum.pedalpcb.com
Also, I think I've got more versions of the 4049 than TI. No 14-pin versions like you though...![]()
Exactly. It helps to have a claw hammer nearby for emotional closure.The worst part about that, and stripboard building in general (as far as I have experienced so far) is that if you mess up, it’s almost always easier to start over than to try and fix a mistake…
I'm barely self-aware, so thank you!@Coda & @fig
I've always liked Charlie Barth's Moosapotamus site, he came up with his own Tube Sound Fuzz variant:
The Tube Steak Fuzz
Both of you are probably aware of it already, but I thought it worth mentioning for others who may not be.
