Tayda Pre-Drilled Enclosure LED
jpd
Hi all,
I picked up a few of the Tayda enclosures to try out with a few builds, but the LED hole sizes don’t seem to fit any 3mm LED bezels I have right now. Hole is too small for what I have (assorted 3mm bezels from Tayda, Mouser and others).
Are there particular bezel sizes or types in mind here? If anyone has had luck with particular bezel sizes/types, can you link what you’re using or provide a part number? Ideally I’d like to fit something without having to drill the hole larger.
I drilled it out to 1/2" and used a grinding stone in a drill press to open it up to 0.52". If I'm going to make a habit of using 10mm LEDs, I'll need to find a 17/32" drill bit. Harbor Freight has a stepless drill bit set, I might try that out.
