Ctrl4Smilerz
I got a drilled and painted enclosure from Tayda that I just can't get the screws for the cover in. I tried cleaning the paint, but it goes pretty deep into the hole. Anyone have some tips on how to clear the threads?
That's my normal go to, but it's not working with this one. It looks like a lot of paint got in there.I go slowly, screw half a turn, backup a quarter and continue. If there is to much resistance, I back up a little and retry.
Yes, I contacted them, and they asked if I could clean the threads out. I figured I would check here to see if they are some tricks I didn't think of before pushing back.You’re going to have to use a tap if it’s as bad as it seems. My last batch from Tayda were a little sloppy in that regard. Have you contacted Tayda to ask about it?
HA!chunkies
I haven't found it necessary to use a bottoming tap because the holes really go through the whole enclosure depth. The screws only go in 1/2" or so. I run the tap in about half way and it's gtg.If you’re buying a tap just for this purpose, get a “bottoming” or “plug” style tap, they don’t taper as much and thread cut to the bottom of the hole.
Thanks, that looks perfect.
Funny how you pay for a service and you get a product that requires further work. Before anyone says it, I know Tayda's drill/powder/UV service is a great value, but it could be immensely improved if they'd spend only a couple minutes more on prep....they asked if I could clean the threads out.
Thank you @MichaelW, I wasn't sure what size they were so I learned something new today too! I tried the taps I had on hand and none matched so I'll grab one of these next time I spend money with Dr. Evil.
I'd also recommend running the tap lightly over a candle stub before using it. In my shop for most materials, we switched to using a cutting wax (but especially for this use, candle wax is just fine) instead of cutting oils. Much less mess.But I will add, if you've never used a tap before, there's a bit of a process. Go in one turn then back it out 1/2 a turn, then go in until it "bites" again for a turn, then back it out 1/2 a turn. Otherwise your tap might get stuck....
