caspercody
Having issues with my Bobby build, is there a schematic, and PCB layout? Need it to figure out my build
Is there a BOM or schematic available for the Skeptical Buffer? I’d like to add the necessary components to a Tayda order…
You mean you're gonna add another $25 to the BoM to make it a whatever power supply?The PCB needs to be verified first, just in case some changes are made to the power section.
Looks like it’s using the bipolar supply doubler from the LT1054 datasheet if I was a betting man. I got just north of +/-15v last time I was mucking around with it.I don’t see how this could possibly work without a solid DC-DC converter. I’m surprised there isn’t an AC transformer honestly.
Do you really think the meagre 100mA current ceiling for the LT1054 will be able to handle that circuit? No doubt that is @Robert's concern.Looks like it’s using the bipolar supply doubler from the LT1054 datasheet if I was a betting man
Oh great point, I always forget that limit. Maybe some of that draw on the original is from all the power circuitry?Do you really think the meagre 100mA current ceiling for the LT1054 will be able to handle that circuit? No doubt that is @Robert's concern.
So you're telling me that the power section is engineered so hard that it needs a more robust solution in order to realize it? Bruh.Oh great point, I always forget that limit. Maybe some of that draw on the original is from all the power circuitry?
What are you talking about. More current means faster. The pedal will anticipate your playing. Duh.That would make no sense whatsoever..... then everyone with the correct power supply would just be burning up current for no good reason.
So like, semi-serious question, how close would one be to this not-a-buffer if they had a Kliche Buffer board and a charge pump...Yeah like 99% of it, it has a single TL072.
