owlexifry
i’m probably only going to do like x3 max. i don’t do heaps of builds.LCSC has suitable relays for cheap as chips and good shipping. If you're doing more than a couple relays, then having a vero may end up being a tedious, repetitive process for what is essentially a modular part. I just had 30 made with all the components on SMD except the relay for a buck a piece. With relay, it would have been ~$2.20 each (I just have an inventory of relays to use). That's not such a bad price if you build a lot of pedals.
just wanted to whip up those few on vero.
thanks for the tipIf you’re using a 9v relay, you don’t need to drop voltage/current, so you’d just use a jumper.
That relay is not the size you think it is. Take another look at the datasheet.
is this not the same spacing as in my layout?
