Chuck D. Bones
Circuit Wizard
How many leads on the LED?
Unverified, but maybe something like this would work for your application:How would #1 integrate into your existing simple bypass?
Wow, great minds. That gate stopper resistor (RX5) should be larger to guarantee it does the job. I like 10K for that.Unverified, but maybe something like this would work for your application:
Yes, but the 555 does not have infinite drive capability. When powered by 9V, we cannot expect the 555 to sink more than 30mA. If the sum of the coil currents exceed that, then you need a MOSFET to drive the coils. This is an example "requirements creep" where a circuit works fine until someone changes the requirements.Quick question as I try and do some design work for the Forum Univibe:
If I were to use more than one DPDT relay for the Speed switching, am I correct in this assumption:
If I place two relay coils in parallel, would I use their parallel resistances in the coil resistance calc to get my proper coil resistor?
I figured the values may need to be adjusted some, but thank you for confirming! I've updated my post above for posterity....That gate stopper resistor (RX5) should be larger...I like 10K for that.
This is cool. You may want to consider posting a new thread for this since it’s not really related to this circuit.This is just FYI. I made a discrete soft-touch toggle circuit for my TPA3118 power amp pedals that would also work for all this stuff, if anyone want such a thing. This link jumps to the post about it in the TPA3118 amp thread.
TPA3118 60W Power Amp Module
EDIT #2: I've decided this is not worth the effort. The only way to really avoid pop is with proper behavior. Don't plug in a speaker cab until everything is powered. Unplug speaker cab first for power down. A mute button or stand-by on the amp might be a nice-to-have, but still requires proper...forum.pedalpcb.com
if you want to reliably drive a latching relay, use a microcontroller.
Is the SPST momentary?For anyone following this relay, I uploaded the v2.1 of my layout:
GitHub - szukalski/pedal-simple-relay
Contribute to szukalski/pedal-simple-relay development by creating an account on GitHub.github.com
It's the same as v2.0 but with a smaller footprint, less height.
I have a v3.0 drawn up which lets you choose to use the LED of the main board or the relay, but it's not smaller than this one.
Yes. You can use any mechanism to make a complete circuit.Is the SPST momentary?
Hi, could you please help with the attributes of U1(when using FTR-B4CA) on relay-v2.1-cpl.csv? Is the rotation =269.99 correct? Seems like it should be 180 based on visual inspection on JLCPCB.For anyone following this relay, I uploaded the v2.1 of my layout:
