You’ll get the LEDs!
First you release as 3PDT
howzabout a stereo version?![]()
Pretty much just that. Secondary relays for each one for stereo.Assuming you mean standard stereo TRS loops it would be fairly simple to make the current prototype stereo.
Logic and relay drive is all on one board, signal path on the other. All it would take is another set of relays on the signal board to switch the ring terminals.
If you end up with a non-programmable switcher it would be really good to have 2 different switching modes:
It should also have a kitchenette and a fish tank…
FWIW . . . . AmplifyFun now does drilling for the 1032L enclosure size. There is a bare bones template available for the 1032L if you want it.The issue there is that we'd need 1032L line cutting / milling and so far we don't even have drilling.
But for all the details, (dunno if he can do line cutting / milling or painting) it's best to contact Spencer Davis directly at AmplifyFun in Portland..
