chris.knudson
Is that a thin line power jack?The spacing on this kewpie fuzz is crazy tight!
There is about 1 cm below the footswitch to push down, but I don't think I'd like that switch position topside.Would there be any room to scoot it down?
Negative.Is that a thin line power jack?
I thought that looked like a Lumberg. I love those, but they are big. I've started using thin line jacks for tight builds because I don't like bending those lugs (which I've had to do a few times like you did there).There is about 1 cm below the footswitch to push down, but I don't think I'd like that switch position topside.
Negative.
https://www.amplifiedparts.com/prod...rg-dc-panel-mount-55mm-external-21mm-internal
Yep, been there.Decided to build a TS9 today around 11am. As of 8pm-ish I have the board done, cuts and links made, and I installed the socket for the IC. I also picked out a color for the paint: neon lime green…
Now, I also have another board that has cuts and links, but the cuts go one way, and the links go the other. Stripboard is hard…but cheap.
Thanks.Less than 5 mm
FirstThis fat bastard held all my 3 legged friends. Was getting pretty unwieldly. Pulled all the PNPs and Fets into a different folder and transitioned the last few 9 pocket pages to 6 pocket pages
Much better, for now.
Still have more parts to put up. Sigh.
But looks so right!
9V is the wrong way around?Sloppy, melty, verification build warning:
Something is wrong here. Can you spot it? (It's not that exposed R19 footprint)
Don't assemble sleep deprived
Bingo9V is the wrong way around?
Bingo
But also, I've discovered other …rather stupidly amateur errors and the board doesn't work at all and is not salvageable.
