After you have cleaned the Board & looked for any bridges or bad joints,
Here is a Continuity Test you can do, No Power connected.
Matching colours should show continuity:
I think Jimi did that a couple of weeks ago. Also, 2 builds with the same issue.A good clean is never a bad idea, but you could also try just subbing the charge pump if you have any extra laying about.
I'll have to look into that flux, too. I clean my boards, but they stay a bit fluxy-sticky
2 to 5 just made other sounds but 2 to 1 got rid of all the buzzing.Do you have any rail to rail opamps to try in IC2? Kinda throwing things at the wall here.
That whole gain stage ticks a lot of the boxes of the linked article of things not to do.
¿Maybe jumper IC2 pin 2 to pin 5(grounded) with the tiniest cap you have? Like, single digit pf tiny.
C8 should be handling that already. Bad batch of whatever you have in C8?2 to 5 just made other sounds but 2 to 1 got rid of all the buzzing.
So, no more oscilation?C8 should be handling that already. Bad batch of whatever you have in C8?
Yep, no more buzzing. Which is stranger, I removed everything individually, including C7, but never everything completely.So, no more oscilation?
Yes, with pins 1 and 2 of IC 2 jumpered it works. Would I be correct in saying, that’s just a tone shaping stage?OK, so where are you actually at with the pedal, is it working now?
Is that a MLCC in C8?Yes, with pins 1 and 2 of IC 2 jumpered it works. Would I be correct in saying, that’s just a tone shaping stage?
Yes it is. Would that make a difference? I was afraid of the possibility of microphonics in a high gain pedal.Is that a MLCC in C8?
Though I think it's just a poorly designed gain block.
Maybe. I'm not a fan of them in the audio path in general but I don't want to kick that debate back up on this thread. If using themin the audio path, c0g type is preferable by far.Yes it is. Would that make a difference? I was afraid of the possibility of microphonics in a high gain pedal.
That makes total sense, I see that now. The pot sounds like it mildly affects the gain. I watched several YouTube videos, it’s hard to tell a difference in the gain rotation.Does the GAIN control work with those pins jumped? If I’m following correctly, you’ve turned the gain control into a unity gain buffer.
He's essentially changing the value of C8, not C6.Does the GAIN control work with those pins jumped? If I’m following correctly, you’ve turned the gain control into a unity gain buffer.
If it is working with pins 1& 2 jumpered & you have Continuity on the Matching Circles in the Diagram above, your issue is with one of the components attached to those circles that are causing the Buzz ie C7, C8, D1, D2, R9, R10 ??? that you have bypassed with the jumper.Yes, with pins 1 and 2 of IC 2 jumpered it works. Would I be correct in saying, that’s just a tone shaping stage?
