Robert
George Cloney
Something I want to know but it's probably dumb; What does FAC stand for? In reference to rotary switches.
The Orange thing?
Gotcha, thanks much! I believe this is what @jwin615 had mentioned, but I got caught up in an alternative method of flying a cap and diode off of the actual Crumb if going straight from the DC Jack... If tapping the cathode of the pcb’s protection diode won’t cause a loop that seems much easier.If you're adding it to an existing build, tap 9V from the cathode of the main PCBs polarity protection diode.
If you're using it standalone (probably not) use a 1N5817 diode instead of wire to connect the positive lug of the DC jack to the PCB.
As far as the values, start with values from one of the Muff variants.
frequency attenuator controlAhh I guess it's Frequency Adjustment Control? I've heard that used before but never knew. And just saw it again when looking at the Magic Pedals DA120
I wasn't aware that service was available. I'll certainly be requesting it from now on.Why do folks ask to have random objects/animals drawn on their packing slip?
To prove you're not a botWhy do folks ask to have random objects/animals drawn on their packing slip?
Can you draw an elephant?Why do folks ask to have random objects/animals drawn on their packing slip?
mostly to see how far you will take it so they can have their viral moment should you go above and beyond ... like those posts of people who asked room service to decorate their room with pictures of Jeff GoldblumWhy do folks ask to have random objects/animals drawn on their packing slip?
Yep, this. Some people don't care about imposition.mostly to see how far you will take it so they can have their viral moment should you go above and beyond ... like those posts of people who asked room service to decorate their room with pictures of Jeff Goldblum
Or when you're debugging a build with one...frequency attenuator control
>-/-8-Oalso if you're not drawing stick figure girls with big boobies, the Stussy S, or just a classic anarchy A I don't even know why you're bothering
The Stussy S! That is going on one of my next builds!also if you're not drawing stick figure girls with big boobies, the Stussy S, or just a classic anarchy A I don't even know why you're bothering
