SWITCH-CRAFT (got any creative uses of switches?)
FOR THOSE TIMES YOUR TOGGLE NEEDS VISUAL-AUGMENTATION BY LEDs
[EDIT]
Explanation of the situation:
To get LED indication for an SPDT on-OFF-on toggle (ALL THREE POSITIONS), I had to resort to a 4PDT on-ON-on toggle.
You say: "Why not just look at the position of the BAT?"
Well on a darkened stage away from your pedalboard, you can just look over at it and SEE THE LIGHT, but not the BAT, man. Woah Man!
The left-most 2 poles operate as per the SPST on-off-on. The middle position is off, nothing connected.
The right 2 poles are for manipulating the RGB-LED, getting a colour for even the "OFF" position of the switch.
To reiterate from its original posting:
Toggle Down = top row connected to common, RED & BLUE (gives you magenta)
Toggle Centre = no connection for SW-1, BLUE ONLY
Toggle Up = bottom row connected to common, GREEN & BLUE (gives you cyan)
NOTE JUMPERS placement.
Make sure you get the right type of 4PDT on-on-on — DPDT equivalent is a TYPE 2. Read the datasheet(s)!
You can mix up the order of colours to taste, and achieve different hues with different CLR value, juggling their values to achieve the desired colour AND brightness.
*** IGNORE R12, that's just there as a reference point from the original circuit this lit-switch was intended for.
R12's
NOT PART OF THE SWITCH(ING)!
Use the 4PDT switchery, minus R12, for any situation you want to replace the SPDT on-off-on for same functionality with LED indication.
IF ANYONE HAS A BETTER WAY OF GETTING LED-INDICATION IN THE "OFF" POSITION, PLEASE POST IT IN THIS THREAD!
Whaa? You’re gonna have to explain this one to the mint-flavored paste kid
It's for someone who wanted LED indication for each position of a SPDT on-off-on switch.
Explained in the following quoted post from that thread:
NOTE the JUMPERS; also, there are different kinds of on-on-on configurations, so make sure you know which configuration your middle position is when ordering 4PDT on-on-on switches. Read the datasheet(s)!
That gives you 3 different colours, one for each position of SW-1. You could stick any of the three colours in the middle position, for instance if you wanted a YELLOW light, you'd combine RED & GREEN.
Since the individual colours on the RGB-LED each have a different forward voltage from their neighbouring colours, it would be best to breadboard the switch to determine what value each CLR needs to be for an even brightness (if so desired!) and colour mixed to taste.
Here's a quick 1-minute primer on colour-mixing with light:
I'll edit the post #22 above with the switch diagram.
[EDIT]
R12's
Now I get it. I looked at “SW-1” and saw an actual switch rather than solder pads. And hadn’t even thought about magneto or ryan, so double thanks.
For anyone who wants both momentary and latching bypass for an effect, without resorting to an Intelligent Relay-based method...
By special request, I was asked to add an LED to the momentary — though not necessary, it adds a bit of fun.
If you don't need/want an LED for the momentary, delete the above 3PDT-momentary's middle pole, and use a DPDT momentary instead.
[EDIT] Request was for one LED...
Buffered bypass with series parallel switch, with and without master-bypass:
Above based off Brett's post in this thread:
Cool, it's actually pretty simple.
You'd wire your switch as follows:
1702681803166-png.63348
Pay close attention to the tags, the I/Os for the effects are re-ordered compared to the previous images. Switch pins are labeled in the schematic.
You could optionally add an indication to the switch setting by going with a 3PDT as follows:
1702682397568-png.63349
