Feral Feline
FOR THOSE TIMES YOUR TOGGLE NEEDS VISUAL-AUGMENTATION BY LEDs
[EDIT]
Explanation of the situation:
To get LED indication for an SPDT on-OFF-on toggle (ALL THREE POSITIONS), I had to resort to a 4PDT on-ON-on toggle.
You say: "Why not just look at the position of the BAT?"
Well on a darkened stage away from your pedalboard, you can just look over at it and SEE THE LIGHT, but not the BAT, man. Woah Man!
The left-most 2 poles operate as per the SPST on-off-on. The middle position is off, nothing connected.
The right 2 poles are for manipulating the RGB-LED, getting a colour for even the "OFF" position of the switch.
To reiterate from its original posting:
Toggle Down = top row connected to common, RED & BLUE (gives you magenta)
Toggle Centre = no connection for SW-1, BLUE ONLY
Toggle Up = bottom row connected to common, GREEN & BLUE (gives you cyan)
NOTE JUMPERS placement.
Make sure you get the right type of 4PDT on-on-on — DPDT equivalent is a TYPE 2. Read the datasheet(s)!
You can mix up the order of colours to taste, and achieve different hues with different CLR value, juggling their values to achieve the desired colour AND brightness.
*** IGNORE R12, that's just there as a reference point from the original circuit this lit-switch was intended for.
R12's NOT PART OF THE SWITCH(ING)!
Use the 4PDT switchery, minus R12, for any situation you want to replace the SPDT on-off-on for same functionality with LED indication.
IF ANYONE HAS A BETTER WAY OF GETTING LED-INDICATION IN THE "OFF" POSITION, PLEASE POST IT IN THIS THREAD!
