A bunch of my friends bought these on another forum. I’d love to see what they can do. But I’m a bit confused by how the buttons change the functions. I’m sure I could learn it, it just seems trouble some to pass through the menusI went ahead and purchased one of these for $89 (including a Daisy Seed).
Sorry, I should have put menu in quotations. The “menu” function being that you push the button, and the led color changes to let you know what set of parameters you’re changing in this specific setup for the software I found a video demo for:There are no menus on the Pod, maybe you're thinking about the Patch?
Regardless, functionality depends entirely on the program you're running.
Oh sure, new DSP as I just ordered my first FV1 development board
Reading through the Daisy Wiki and looking at the Forum, I don't see any talk about simulating code.
Code Simulation is probably not an option at this point right?
Yeah. I liked that about SpinCad Designer.How do you mean? Like running code on a PC?
Any updates about when the terrarium could be available? I've been messing around with spinCAD/asm but I'm pretty new to pedal building so I could definitely use something like this!The Daisy module is powered by 9V, but has onboard regulators for the various ICs.
I'm using 10K linear pots at the moment because that's what the "Petal" used. 100K could be a better option since it would put less idle load on the 3.3V supply, but I just wasn't feeling very experimental yet.
Yep, TL072 for the buffers.
I just finished up the Terrarium prototype, all is working good so these will likely start becoming available in the next restock.
are those the full size 1 UF box caps to go under the daisy seed? those seem to be taller than the 40 pin socket I cut apart to mount on the PCB.
