I use two PT2399 in parallel for a pedal, that works pretty decent. Just two standard PT2399 datasheet delay lines, going into the same summing opamp with the dry signal. tweak the response of each line with the built in input opamp of the PT2399s (hooked up as multiple feedback band pass filters - at LPF1), I added a switch to choose either parallel or "cascade", where feedback of delay A goes into input of delay B and vice versa. I liked the idea of having different speed and feedback for differently voiced delay lines.
