- Patented Analog Design
A completely original circuit that cannot be replicated or reverse-engineered using conventional designs.
Haven’t seen this circuit, but if it statement is too good or bold to be true…well, you know…
- Transformer-Based Guitar Profiling
A dedicated transformer dynamically switches between STRAT and LP modes, adapting the pedal’s internal behavior to single-coil or humbucker guitars with absolute authenticity.
Orman's PU sim ’roids with phase flip?
- Hidden Internal Controls
Precision-tuned internal parameters, including a MID / 1.2 kHz shaping circuit, allow exact harmonic voicing consistent with vintage PAF resonance.
Metal films, modern smd yeah sure it’s precise, but it’s just a mids pot.
- Out-of-Phase Engine (Never Done Before)
A true analog Out-of-Phase circuit inside a pedal. The input signal is split, phase-shifted, and recombined into a mono output—delivering the unmistakable “Greeny / Gary Moore” tone without modifying your guitar or wiring.
Op amp buffer to parallel processing with transformer, gain, eq and mixed before output?
- Microphonic PAF Emulation
Faithfully recreates the airy, vocal, unwaxed PAF response—dynamic, touch-sensitive, and alive.
I’ve made microphonic circuits too with bad soldering and components. Nothing to brag about…
- Universal Compatibility
Designed to work with anyguitar:
- Single-coils, P90s, dogears, Strat-style pickups
- Humbuckers of any type, from budget pickups to genuine Burst PAFs
- Can even be used with real PAFs to enhance harmonic highs and tonal color
Yo dawg i herd u like pafs so we built a paf emulation after your pafs.
Isn’t universumal compatibility bad thing for pedal biz, ’cos then theres no room for
Yet Another *insert pedal type here*.
BUT how this works with different amp setups? Does it Paf Up different types of amps? Will it Paf Up MicroCube? Does it help putting this after microphone to sing vetter vocals like in Paffing up way? Is this one circuit to Paf ’em all?
Edit. Oh and the patent thing. A turd thrower is patentable, but does it have any other use than making a shit storm?
