Yep, I did wire it the way described.Do you have the ground wire from the DC jack going to the board, if so your good, the black wire from battery clip should be on the input jack
Do you have Sound in Bypass mode?Yep, I did wire it the way described.
Im baffled.. My LEDS turn on correctly, but there is literally 0 sound.
I looked for shorts, nothing. I reflowed and still nothing.![]()
We do need you to respond to the Questions!Do you have Sound in Bypass mode?
What voltage are you getting at Pin 8 on both JRC4580D's ???
We need to see the back of the PCB board!!!
Clean those Nine pins !, The Board also needs a Clean.
Ok so i just clipped the header pins and took off the footswitch board from the mainboard.Clean those Nine pins !, The Board also needs a Clean.
Pull your Footswitch Adapter Board from the Main PCB & Test the Matching circles again.
If you have Continuity to Ground from Yellows and Purples its the Main Board!
Make sure all your Potentiometers are 1/2 way on rotation!
If not, It's the Footswitch Board.
As Big Monk said, With both Footswitch's in Bypass & Active modes , Test each Footswitch Pad for Continuity to see if Solder underneath is touching lug next to it that is causing short.So you have proper continuity from the 9 main board pins to the corresponding places on the main board?
Have you also checked the 9 pins on the breakout board to their places on the footswitches?
Don’t mangle the board getting switches off until you are sure.
So i did the continuity test for the 3pdt stomp switches, they’re both shorting, i used too much solder unfortunately. But good news is the main board is good to rewire. I’ll just order some new 3pdt switches and try again.So you have proper continuity from the 9 main board pins to the corresponding places on the main board?
Yes, it looks like a lot of solder & heat on those footswitch pads.Check for Continuity on these Matching Circles from matching Pin Pads on Adapter Board with Footswitch's:
the bypass quadrant on the right are all showing continuity even when active is switched. I now learned that you can damage a switch by heat.From the photos the switches don't look poorly soldered. What do you mean when you say they are shorting? These switches can be prone to too much heat. If they did get too hot when you soldered them then they may be faulty.
Im going to just wire them manually, I dont even know how i would desolder the footswitchesYes, it looks like a lot of solder & heat on those footswitch pads.
Are you going to reuse the Adapter Board or Wire the individual Footswitches
When soldering Footswitch or Toggle switches, never Solder next to each others pad, skip one & wait for each one to cool!!!
I'm all about hot and fast...HAHAI've damaged enough switches to know you have to get in there hot and fast, with just enough solder to fill the pads and no more, and work in a pattern like tightening a pipe flange.
I do corners, then the middle, then a diamond.
