drgonzo1969
mmmmm sanndwich
mmmmm sanndwich
Is it a sandwich or sammich?mmmmm sanndwich
Depends on the funk.Is it a sandwich or sammich?
Any update on this?
Any update on this?
I never could have told if you hadn’t pointed it out! Is that for a pedal or to mount in a guitar? Also how do you solder in, out and power?Just a little boost...
Really disappointed that I installed the 390R backwards....![]()
At first I thought that 1n5817 was a MELF resistor.
Flat Boost? How about a wide Q mid boost? Like the Demeter Fat boost?I had pedals in mind but I suppose you could use it in either?
They're through-hole pads, they're just filled with solder from testing.
That's generally how I connect offboard wires, especially if I'm planning to remove them... fill the pads with solder and "surface mount" the wire onto the pad. Faster and more secure than any quick-connect, socket, or clip lead.
hmmmm lemme guess....a Revv pedal?
ehx bender royalehmmmm lemme guess....a Revv pedal?
I actually had a chance to somewhat trace the Fortin Blade from an old bandmate, couldn't pull any components though. It is yet another TC Electronics Integrated Preamp that's been modded, I had actually used your clone board to make some approximations. I'll have dig one of them out to see what I did exactly since it was about three years ago.
