The A/K markings are for the case where you want to mount an LED directly to the module, rather than use the LED on the main effect PCB.
You'd omit the 2N3904 and install an LED in the pads as marked. R2 becomes the LED current limiting resistor and the value should be adjusted accordingly.
For typical usage just ignore those markings.
