These onesThe hole is small
I have one of these, the end pokes out. Anything that fits here without a protruding end?
Indeed thank you. Even though Lumberg is great you don’t see brands in the store with protruding jacks like thisAll of the through-enclosure DC jacks will protrude somewhat.
If you want a completely flush mounted DC jack you'd need to use the Power I/O module, but it's not compatible with the pre-drilled enclosures.
They're using board-mounted jacksIndeed thank you. Even though Lumberg is great you don’t see brands in the store with protruding jacks like this
JHS still does I think, most brands are using board mounted stuff for fastest assembly, but it's a little more difficult for DIY stuff because there are so many variables when you send out a DIY project as far as what people will have access to in their area and such.Indeed thank you. Even though Lumberg is great you don’t see brands in the store with protruding jacks like this
I think the snap in lenses.I've been meaning to ask @PedalPCB, is the LED hole for the pre-drilled enclosures supposed to match any specific bezel? I have to widen it for every bezel I've tried.
It's sized for the 3mm lenses, although I'm not sure if any suppliers carry them at the moment.
I need to get more.
3mm LED Lampshade Protector Clear Plastic Clip
Get It Fast - Same Day Shippingwww.taydaelectronics.com
Every question here has been answered, but I want to chime in and agree with this. The cheaper knockoffs of the Lumberg are terrible. I understand trying to save a buck here and there when building, but the Lumberg DC jack is 100% worth the extra money.FWIW make sure you get Lumberg DC jacks. The cheaper versions of that jack are terrible!
Has anyone had Tayda cut the openings for this yet? Would be cool to get the dims since they do square cuts now.All of the through-enclosure DC jacks will protrude somewhat.
