DGWVI
This one's fairly straight forward. Captain Bit > Minnow > Dark Rift, all with a few mods.
The Captain bit has been modded with a 2KB pot between the C2 and Pin 1 of the 386. I've also hacked in one of the Tone Control boards between C5 and Pin 6 of the Transformer, built to modified Foxx tone specs. This Ranges from a great tracking up octave, to insanely trebly and nasty. I chose to go with something that would drop a few decibels, as it was a little too easy to oversaturate the octave up portion
The only mod to the Minnow has been to move the trimpots to the face of the enclosure. A lot of awesome sounds to had with these as external controls
Mods to the Dark Rift include
- Shape Pot is now 500kA
- R13 & R18 are now 47k to kill a bit more of the dry signal and boost overall output a tad
- R8 is 15k, though I may reduce this further as it's currently not capable of self oscillation
- R22 & R31 have been decreased to 10k
- I've inserted a zener diode between Pin 2 of of the regulator and ground, to bump the voltage up to around 6 which enables slightly lower minimum delay times (I'll swap his out for an actual 6v regulator once I get them in)
- R26 is now on a DPDT toggle that changes between a 47k and a Parasit Modboard, which modulates the speed and is capable of giving stutters, flutters, and some pseudo arpeggiation. It's most noticeable the further toward the square side of the shape pot you go.
