Cordyceps Ring Modulator Build Doc?
Is anyone using an existing drill template for the Cordycepts Ring Modulator? I'd try to measure it out, but I can't measure worth a @#$%.
i was hoping for just a standard pedal pcb build doc, but i did find the parts list and took note of the drill template above. Maybe that's all I need. I'm new-ish to building pedals (about 15 under my belt) and i just have a very particular workflow that works for me at the moment. If there isn't a standard document, i'll survive.
I’m confused by the parts list vs the screenprinting on the pcb. The ICs don’t match in total quantity or part. IMG_3830.jpeg
Something bad wrong with that BOM, not sure what happened there.
I'll get it reposted today, possibly with the complete doc if I can get the time.
Looking for this build doc and schematic, is it available?
Are we talking about the oscillator bleeding into other pedals (like when the Nutty Fuzz is bypassed) or more like a gate that kills the oscillator when you aren't playing? (I suppose one solution would solve both problems)
Take a look at the Cordyceps schematic, it uses a simple opto based gate to mute the carrier signal when you stop playing.
EDIT: Well, you know, it would help if someone would post the damned schematic. Give me a just a bit. :ROFLMAO: :ROFLMAO:
