Mentaltossflycoon
So I put together a dizzy elk inspired by @peccary 's build report. It works but I wanted to confer with y'all about the transistors. I bought some mp38 from Ukraine and they're all testing in a tightish range on my tc-1 (best I have rn, thanks again @fig). This means I have an ok selection of gain for Q1 and Q2 between 55 and 72 but Q3 should be more in the 100 range. I socketed them and have been digging around the small amount of germs I have and found an ac127 that's around 100 and an unbranded metal can around 120. No idea about leakage so I've tried a lot of combinations finding the best results with the highest gain mp38 (72) and a pair around 67 for Q1 and Q2.
It sounds amazing with everything maxed. The volume sustain knob seems to be fine but the other two have a major drop in volume when not cranked. I'm hoping this just means I need to keep on searching for the right set of transistors but if this sounds like another issue I'm hoping y'all will know what's up. I found little difference between any of the mp38 in Q1 and Q2. The unbranded in Q3 sounded ok and the ac127 sounded similar to the mp38. The rest of my germs are higher gain. Should I just finally order a Peak tester? I'm just not that germaniumy but I'm assuming I need a leakier Q3 than I have.
At full blast, I like it enough to box it as is but I feel like it isn't right.
