Pete's Pedals
Makes the dreaded ticking noise, but only if the left side (the green knobs) is turned on. If the red side is on it sounds wonderful, and I can switch between which LFO is controlling the speed and depth. When running the in and out just through the left (green) side the effect is not as pronounced as when I run it just through the right (red) side. The red side also seems more sensitive to changing settings on the trimpots while the green side trimmers, though changing what happens with the LED, doesn't seem to change much with the actual sound of the effect. I tried moving the input wire farther away from the LED on the green side, but it made no difference. Any suggestions
