Bottom right corner of the LDR board, looks like there should be a 47k and a 4.7k, but the two resistors look to be the same.
Side note - I fully respect using what you've got around to get something done, but in the interest of easier troubleshooting, there is an advantage to using all the same resistor type, and orienting them all the same way (brown tolerance bands all pointing one direction). Makes it much easier to double check the values after the fact.
