Electrovibe
Anyone know of a U.S. supplier for the bulb and LDRs now that small bear is out of stock? For some reason I’m not able to order thru Banzai
Mouser has the bulbs.
Digikey has 9203 LDRs but they are actually 9200 spec.
Jameco has legit 9203 LDRs and the bulb but a $20 minimum.
Heyo!! any leads on the proper bulb and LDR for this I'm looking at these two from Digikey and wondering if they'll do the job!
This one from Jameco is actually closer to the spec for the 9203 on the data sheet from SBE:
The Digikey units are actually closer in spec to the 9200:
At the end of the day it should make too drastic a difference. I’ve used both and while it seems a marginal amount of extra depth is available with the true 9203, most people won’t notice, especially with the lamp brightness control circuit inside to adjust.
