What transistors did you end up with? I used 2n3903 in all three positions (hFE ~120) and found it to work quite well. Changed the fuzz knob to a C-taper to avoid bunching up with the sweep.Just built the prototype, man, this thing is outstanding.
Curious, did you go with carbons for the mojo or the standard metal film resistors?I used 2N3904, hFE around 200.
I’d like to build two side by side one with each to see if I can hear a difference.
Sorry, what does “R.G.” stand for?
Sorry, R G Keen. That’s a link to some notes on carbon comp resistors. Basically, the qualities people dig happen at much higher voltages than pedal circuits provide.Sorry, what does “R.G.” stand for?
Did you use the c-taper? That’s the only thing beyond transistor choice that’ll have an appreciable impact.
So then, Different taper pot with same value will make it sound Better !!!?Yeah that part sounds different, better sweep. Sounds the same at full bore.
Kinda what I was thinking. Thanks!
Gotcha, thanks for clarifying.Sorry, R G Keen. That’s a link to some notes on carbon comp resistors. Basically, the qualities people dig happen at much higher voltages than pedal circuits provide.
