MichaelW
This would be cool.And helpful for a pedal board that has FF's as well as Delays and other stuff. I could live without the boost. One loop buffered, one unbuffered for FF's.....
Upvote
23
This would be cool. Anyone know of mini push button switch like the phase switch on the Swiss things?
My guess is it was a functional thing that came out of prototyping, kinda ugly but for their intended usecase - swiss things at top right of your board, bottom row of your board is all gain, top row of your board is all mod and time effects, make sure all foot switches are far enough apart for no accidental presses - I can see how this particular layout would come out on top.I always wondered what was up with the form factor of this thing. Does it make sense to any of you?
Same, my dude, sameMy first thought was, "..no graphics, Earthquaker? ..wtf?"
That would be super sweet,So what are we saying, a clean blend on each of the loops?
And we want it all for 10 bucks.That would be super sweet,
- Blend/mix knob on both loops
- Loop #1 w/input buffer, tails bypass
- Loop #2 unbuffered (for Fuzz Faces and the like)
- Loops can be turned on/off independently
- Truebypass passthrough
- Skip the boost circuit, I'd rather choose the flavor of boost before or after the box.
- tuner send
- expression pedal for overall volume control
That's my wishlist.....
I will go as high as $11, maybe $12.And we want it all for 10 bucks.
Wow you guys are so cheap.....And we want it all for 10 bucks.
Yah for sure the OBNE handles all the blending and mixing. This what I was hoping to build with the GCPCB Paramix board. Only 2 loops in my case. Or some amalgamation of the Paramix plus the GGG Dual IC buffer or the PPCB Simple JFet buffer board, all stuffed into a 1590bIs the OBNE signal blender closer to what you want?
From what I can figure out: The signal blender, the Klein bottle, and the Swiss thing are all a bit different. They all “mix” but not in the same way. Are any of them “the best” or are they just different?
Hmmm, one thing I forgot, phase reversal. I learned this the hard way when I tried using the Buff n Blend board. Not all pedals like to be blended due to phase issues. So there's got to be a way to reverse phase.That would be super sweet,
- tuner send
