The Gator
I have started using jst XH-2.54 connectors. I connect the switchboard and the io power board with an in. wire and an out wire. I use a 4-pin connector on the main board from the switchboard and a two pin going from the io board to the main board. This seems to work pretty well. Although the 2 pin connector does crowd the input and output solder holes on the IO board.
I am trying to keep the connector count low as you could put a connector on both ends of every wire if you wanted to spend the time and money.
Robert, you ever think about carrying some connectors for sale?
Thank you
-Gator
Thank you
-Gator
