Pictures of the build?
that's a great idea. how do you connect the board to it?That’s why I built a test rig! Less things to debug, especially 3pdt switches haha
did you find some sites that show you how to use your digital multimeter? should be a few that come up with a search.
for starters you can check out the guides here: https://guitarpcb.com/forums/topic/pedal-building-guides-mandatory-reading/
nice. must tryI wired up an enclosure with all the usual off board wiring, then in place of the board wires I used cables with alligator clips attached to them. Wire a few flying leads off the board, clip em on and voila!
I find that an audio probe is more useful than a multi meter. I definitely use it more often. You can follow the schematic and test each component and see if there's audio and find the point where it stops. Incidentally there's an audio probe built into the test rig I recommended (I promise Im not being paid to shill it, it's just awesome).I found some on operating the MM but none regarding the specifics of going through a circuit. I'll check out the link. thanks. I'm swamped with work lately so I'm neglecting my builds
