Which version did you go for?
(I'd like to get both)![]()
I built the more traditional version but will likely order the multirange version soon. I suggest getting the PCB + ICs combination. If you usually order pots from Tayda for other projects or have an existing inventory you can pass on getting the set of pots for the pedal.Which version did you go for?
online sources suggest they are interchangeable, but there have been reports of bad MN3207s being sold. Probably one of the reasons that the V3207D was put into production.Is the V3207D can be replaced with the MN3207
Good to know! I was looking for the Coolaudio one but i ended on ebay with some MN3207. I'll try to find some V3207D that can be shipped to canada...online sources suggest they are interchangeable, but there have been reports of bad MN3207s being sold. Probably one of the reasons that the V3207D was put into production.
The Coolaudio V3207 (a replacement for the MN3207) is a low-noise analog delay line capable of delaying an analog signal up to 51.2msec. ......
This device is functionally compatible to the Panasonic MN3207.
muskding: CoolAudio V3207D, 1024 stage low noisde BBD, Analog Delay. Compatible to MN3207.
http://smallbear-electronics.mybigcommerce.com/alpha-dual-gang-16mm-pc-mount/ they have the 1M Log Dual is it working?I think they only stock the 1M Linear Dual, Not 1M Log Dual.
What DIP switch is needed for the Low Tide? Does Tayda stock it?
I believe this is the correct one - TaydaWhat DIP switch is needed for the Low Tide? Does Tayda stock it?
I believe that the LM358 is a drop-in replacement for the LM258.ok is this good for the LM78L05?
L7805CV-DG LM7805 L7805 7805 Voltage Regulator IC 5V 1.5A
SGS THOMSON - Get It Fast - Same Day Shippingwww.taydaelectronics.com
i have all the parts , i just need one LM258P, where i can find one?
Looking at the image of the PCB, there are 4 holes for a BOOST and PAD switch. I don't see a part like that at Tayda. Mouser probably has what is needed, but I imagine we can jumper the pins on the PCB to use with a guitar and other pedals (or use wires to connect to whatever kind of switch(es) you want to mount externally.I believe this is the correct one - Tayda
And from Mouser:
My understanding is the dipswitches are as follows:
1. 6 DB Boost
2.. 6 DB Pad and impedance adjustment for line level instruments
This is something I might put on the front panel to switch between guitars and keys on the fly. I'm not sure what the right parts would be for tacking on top-side flip switches. I will have to look into it...
The picture is generic for all the parts of that model. The one with 2 dip switches will have four pins. I just confirmed it in the datasheet to make sure.Looking at the image of the PCB, there are 4 holes for a BOOST and PAD switch. I don't see a part like that at Tayda. Mouser probably has what is needed, but I imagine we can jumper the pins on the PCB to use with a guitar and other pedals (or use wires to connect to whatever kind of switch(es) you want to mount externally.
The board also looks like it may have an optional SMD mount for the J201.
