I got it running and dialed in. What a fun effect! Thanks a ton for making this happen.Preliminary build doc is up: http://www.pedalpcb.com/docs/LowTide-PedalPCB.pdf
What did you end up doing for the j201 and 2SK208-Y? Did you go with the smd stuff?I got it running and dialed in. What a fun effect! Thanks a ton for making this happen.
I have a big bag of through hole J201s that I bought back when they went on the last time buy list, so I used them. I’m sure the SMDs would work just as well.What did you end up doing for the j201 and 2SK208-Y? Did you go with the smd stuff?
Haven't biased a bbd chip before. Is it audibly pretty obvious when you have it set correctly?I set the BBD/BIAS trim pot similar to the pot on a CE-2 or Caesar. Adjust for the least amount of distortion with chorusing.
The GATE trim pot is user preference, it controls the frequency of the low pass filter portion of the gate.
It is pretty obvious. Set the depth to 100% and turn up the output/amp loud enough to clearly hear the signal. There is a range on the trimmer where you will hear the chorus effect. At either end of the range, there is quite a bit of fizz. Just set the trimmer for the least noise.Haven't biased a bbd chip before. Is it audibly pretty obvious when you have it set correctly?
You will go down in History if yoiu are the first to show this Build!!!It is pretty obvious. Set the depth to 100% and turn up the output/amp loud enough to clearly hear the signal. There is a range on the trimmer where you will hear the chorus effect. At either end of the range, there is quite a bit of fizz. Just set the trimmer for the least noise.
I did have to fiddle with the external gate pot on mine to get a setting where I could hear the chorusing clearly…you may have to play around a little to get it completely tuned in.
I'll buy one off you if you can spare a square. Seems all supplies have dried up.I got 4x V3207D from Barry as well. Not sure I'll use them all, so if I have any spares after I finish my builds, I'll post here and would be happy to sell them at cost to anyone who needs one.
I'll let you know when I finish my builds.I'll buy one off you if you can spare a square. Seems all supplies have dried up.
Where are you Grounded?This one is certainly a challenge to find all the parts for! I think I've just about chased down everything, but the BAT48's are only available from Mouser in the US. Any good subs for those that would work well but might be in-stock from Tayda? My apologies, I'm no electronics engineer!
My ground connection is plugged into a wall in Seattle, Washington in the USWhere are you Grounded?
Isn't mouser based out of Texas? If so wouldn't that be quicker than tayda?My ground connection is plugged into a wall in Seattle, Washington in the US![]()
