Missing Build Docs / Schematics
Howdy @Robert
Got a drill template for the Rock Star distortion? Can't think of any other PCBs that have the same 3-inline knobs with a switch below whose document I could go off of.
Bumping for an Octarock schem. I've got one built up, but I'm having an issue with the sub octave and would like to get it sorted
Still needing the schem for this one.
The upper octave and direct signal work, but I'm having an issue with the Sub-Octave. When first powered up, it runs fine, but quickly dies out in a few seconds, and just becomes ridiculously quiet
I could’ve sworn I saw this somewhere before but now I can’t seem to find it. Seconded…
Found this should take care of it for me.
The diagram isn't drawn up yet but it's pretty straightforward.
+/- go to the corresponding lugs of the DC jack.
IN goes to Input Jack Tip
OUT goes to Output Jack Tip
Each jack grounds to their nearest GND pad
The two 3PDT breakout boards are direct pin-for-pin connections.
See this build report for an example:
I'll get those schematics to you ASAP.
Are there any wiring or docs for the Byzantium? Thanks
Is there a schematic for the Bobby available?
Edit - I see they are available for the Cetus and John, those are probably the same but with different component values or at least close enough to use so I'll go with that for the probe until the right one is available. In case anyone else is looking for the same thing.
Is there a drill template for the XS Drive (Xotic SL Drive)? I've been searching the forum and can't find anything. Can we just like use the hydra for the toggle locations, then use a 3knob template for the knobs?
