Can you share a BOM for the Cobbler?Any info about the flock schematic and all the Victory style preamps?
Triad?Howdy @Robert
Got a drill template for the Rock Star distortion? Can't think of any other PCBs that have the same 3-inline knobs with a switch below whose document I could go off of.
Somehow missed that one altogether. That should definitely do the trick! ThanksTriad?
VB-2 schematic? Been curious about this one for a while now.... Did you use the BA6xx chips or just use more modern IC's?
Still needing the schem for this one.Bumping for an Octarock schem. I've got one built up, but I'm having an issue with the sub octave and would like to get it sorted
I could’ve sworn I saw this somewhere before but now I can’t seem to find it. Seconded…Can you share a BOM for the Cobbler?
Found this should take care of it for me.I could’ve sworn I saw this somewhere before but now I can’t seem to find it. Seconded…
The diagram isn't drawn up yet but it's pretty straightforward.
+/- go to the corresponding lugs of the DC jack.
IN goes to Input Jack Tip
OUT goes to Output Jack Tip
Each jack grounds to their nearest GND pad
The two 3PDT breakout boards are direct pin-for-pin connections.
See this build report for an example:
Fordable Boost+Drive
Very straightforward build, @Robert said it’s a little tight, and it is, so you should definitely put the 3PDTs in first, solder only one leg of each pot, and then get everything test-fit first before tightening all the nuts and soldering all the pots (which I guess technically you should do for...forum.pedalpcb.com
Are there any wiring or docs for the Byzantium? ThanksI'll get those schematics to you ASAP.
