Bricksnbeatles
Member known well
I was just looking at the Muffin build docs, and I noticed that the BOM for the triangle muff isn’t entirely consistent with the schematics I’ve seen in the past for the Triangle revision of the big muff— for example the BOM for the Triangle revision says to omit R8, which goes from the base of Q2 to ground, however every triangle muff schematic I’ve found on the internet shows there as being a 100K resistor from the base of Q2 to ground. Likewise with C2, which goes between the collector and base of Q1— it’s omitted from triangle BOM for the muffin, but every schematic for a Triangle Big Muff shows a 500pF or 470pF cap between the base and collector of Q1.
Some of the actual part values are also pretty different from the schematics I’ve seen— the Fox revision is much more similar to any of the Triangle schematics I’ve found, which makes sense as the three-knob Guild Foxey Lady was to my understanding, the *exact* same circuit revision as the Triangle muff (since they were just rebranded big muffs).
Just wondering what the reason is for these discrepancies— is the Triangle Muffin BOM based on a particular modded triangle muff that I’m unaware of, or perhaps the recent 1590B sized triangle muff that EHX is making now?
