mywmyw
I bought a bunch of bright pink, orange, green, and yellow accoutrement that i'll be using for a series of neon builds. My first time using a predrilled tayda enclosure and . didnt save that much time cause i had to open up every single hole. Went too far on the step bit with the led bezel hole, so i covered it up with an extra hex nut. I like that there was juuuust enough room for the battery on the side. On builds with bigger boards though, the low position of the stomp switch hole would make fitting a battery down there impossible. if i had used longer leads to the switch board, i probably could have had enough slack to fit the battery on top. just food for thought.
also: for those who use molex on the 4 leads ot the switch, what connectors do i need? i bought a 4 pin boy and female housing, but i think i forgot a crimp connector or something? im unsure how it all goes together, never done it before. thanks in advance.
