Panspermeria No Effect Sound When Turned On
leadfoot
I just wrapped up soldering a Panspermeria Fuzz PCB. When I plugged it in, I received very splattery inconsistent effect that didn't seem to pick up the playing of the guitar. So, I rechecked all my wiring, my soldering, etc. and that all looked fine. I then looked over the build document and saw that the PCB has an extra 10k resistor on the left hand side that the build document does not have. I desoldered that 10k resistor and went from having some sound to no sound when the effect is turned on.
I've verified:
1. power comes to the effect when turned on
2. 3dpt switch is operating as expected
3. all components are soldered correctly
4. all components are the correct values
I've attached an image of the pcb before I removed the 10k resistor in the lower left-hand side of the board and after. Is there something obvious I am missing? I had looked at the other Panspermeria Fuzz threads here before posting.
Thanks in advance for the help.
Steady state:
Pin 6 on IC (LM386N-4): 8.31V
(assumming left to right ordering of transistors and checking collector voltages (pin 3)
Q1c: 8.26V
Q2c: 1.48V
Q3c: 0.0v (could be wrong, couldn't get a good read on it)
measure each pin of ICs and transistors (which did you use?) and report back, also a picture of the back would be good. You also have 2 current limiting resistors (main pcb and breakout) that arent necessary.
I have attached a shot of the back of the pcb in the first post.
As far as the CLRs, I don't mind modifying the breakout board to remove and jump the CLR and LED there since I use the LED in the main board.
Transistors are all 2N5088.
Voltages for IC @ steady state, sustain at 0, vol ~50%
PinVoltagePin Desc.
11.297VGain
2-0.005V- input
30.094V+ input
40VGnd
53.729VVout
68.3VVs
74.16VBypass
81.298VGain
Steady state:
Q1c: 8.26V
Q2c: 1.48V
Q2 and Q3 voltages are off, especially Q3. This would explain no signal since there isn't any voltage to turn it on!
Yup and the resistor I removed (which looks to be R1) based on a previous post that I probably misread is connected to pin 1 of the B100K pot essentially removing sustain control from the circuit. :(
I'd put that 10k resistor back in there and retest voltages.
Or put in a socket in case you want to pull it out again
Added 10k resistor back in and it works. How sensitive is the circuit to guitar volume? Based on my playing (Les Paul and Stratocaster) the volume needs to be ~7 or higher at the guitar to really get anything out of the circuit -- below that its just the occasional snap crackle and pop.
I've breadboarded this circuit and it's kind of a one trick pony if you've got hotter pickups. Looking at your OP pics you may need to clean the board with some isopropyl alcohol and touch up some solder joints.
Can you provide updated voltage readings?
My pick ups aren't too hot just standard Burstbuckers in the LP and some Klein Epic '54s in the strat.
I'll be cleaning and touching up once the effect is up and running well. It's the joy of working on it after the family is in bed. :)
Pin (LM386N-4)Voltage
11.298V
20.006V
30.007V
40V
53.895V
68.15V
74.081V
81.291V
Transistor (2N5088)Collector Voltage
10.656V
21.456V
30.975V
