Abyssmal
Hello
Some help would be very appreciated.
I was using my parentheses since a little while now, i never noticed this much noise when activating the octave, is this normal?
Here's a video using the clean channel of my amp and the guitar was connected to the pedal but with the guitar volume down.
I tried it outside my big pedalboard and it's the same noise.
Also tried my second pedal build with the same parts and it's also the same behavior...
I tried OP07CP and LM741, both from Tayda as well as all other parts.
The two Germanium diodes on the picture are now in reverse position, i think there was an error on the pcb silkscreen for this v1
If i use only 1 jack at the input and no jack at the output there is a constant high pitch oscillation no matter what i do with it even with octave off and i can see the LED inside the pedal going ON when the oscillation starts while increasing the gain pot, then when i insert a jack at the output stock, this oscillation goes away but the octave noise remain present.
Please don't blame it on the soldering skills, i solder since 7 years now, that's probably not the problem.
