ChrsGuit
So, I recently completed three identical Boteh drive builds... one for me, two for friends...
Two sound relatively identical... One is considerably louder than the other two... To narrow down the issue, I'll also add that the louder of the three also passes signal when the volume on the pedal is at "0", which I can assume is possibly my issue... like the potentiometer is not applying the resistance that it should to properly regulate the output. I confirmed both volume pots are the correct B100k, and all solder joints appear to be intact. What would be my first step in locating the issue? The leg on R18 (511k resistor) looks a little suspicious to me at a glance, like it might not quite be seated like the rest are... so that was going to be my first target...
Enclosed are a shot of the internals and the schematic. (also note, the Q2 is the "wrong" component. I made this mistake on my first build, but shooting it out against the name-brand counterpart, I preferred the sound, so I repeated it on the subsequent builds.)
