I like the dip switch idea as well. I find that I enjoy using pedals with easy to use analog 1 component has 1 function control.As much as I would like to see you put out some more advanced projects, I realize that would be catering to a smaller subset of your customer base. So I think the dip switches might be the more straightforward way to go, less intimidating, and ease of use and ability to acquire parts and build
Just read your comment on the milling I can. See that would be difficult for 5 dip switches. What if each loop also had an indicator LED and a momentary toggle/push button. When you press the stomp switch it illuminates the LEDs for the loops that you are turning on. When you hold down the stomp switch and press one of the momentary buttons by the LED it turn the light on or off and that is how you select which loops will be used for that foot switch. I still think the DIP switches are more intuitive but this would get rid of the milling and require drilling only. It sure what the electronics part would look like tho.The biggest problem I see with dipswitches is physical space and milling the enclosure.
Which reminds me, if everyone could shoot Hugo at Tayda a message expressing interest in powdercoating / drilling service for the 1032L that'd be great.![]()
To spend hours trying to get everything straight, burning at least two fingers, borking 2 footswitches, then throwing the $60 worth of hardware in the box with the other failures.so, what does this thing do and why do I need it?
This is my previous thread that had all my wish list items:
It ain't that hard -- building a pedal from a pcb and a pile of resistors is harder. Besides, there are other forums you can point users to for help with Arduinos. But I get it -- keeping up with libraries and code is a whole other set of problems.introduced by expecting the builder to flash their own Arduino....
Five loops, but there are thirteen ¼" jacks. Would you be so kind as to clarify? I can't seem to sort out how that works.Creating this thread as a place to consolidate all the ramblings about the upcoming true bypass loop pedals
Tuner outFive loops, but there are thirteen ¼" jacks. Would you be so kind as to clarify? I can't seem to sort out how that works.
OK, so 1 pair for straight thru I/O (no loop), 5 pairs for the five I/O loops, and an extra 1 out (total of 13 ¼" jacks) for tuner out. Right?Tuner out
Without knowing the exact functionality, that's hard to answer. Saturnworks sells true bypass loopers for remarkably cheap (~$130 for five loops).How much does a comparable unit cost in the market?
We can make room.Any room for a common buffer on a switch?
Those are closer to the one I'm drawing up today. Passive 3PDT switching, no relays.Without knowing the exact functionality, that's hard to answer. Saturnworks sells true bypass loopers for remarkably cheap (~$130 for five loops).
I think at that point we’d be wading into Arduino territory though.
