A100K for volume isn't a bad idea... You'll have more control at lower levels but the same amount of volume on tap if you decide you need it.
The resistance of the LDRs will factor in to how much gain the volume control is capable of.
I used KE-10720 for both the single and dual prototypes and it worked perfectly fine.
